Consle port on os6850 doesnt work
aviviis
Post by aviviis » 11 Mar 2018 14:35
When i connect to console port at 9600 and doing reboot , i see all the logs at the console when the os6850 comming up , at the final i see the user prompt but when i try to type something it doesnt react !
devnull
Re: Consle port on os6850 doesnt work
Post by devnull » 15 Mar 2018 04:53
Maybe wrong setting of XON/XOFF/Flow Control?
Use 9600/8/N/1 ?
aviviis
Post by aviviis » 16 Mar 2018 10:10
Yes .
After i reboot the switch i see all the log
At the laptop , until i am getting the user:
I type at my laptop and i cant see it at the screen.
I take another 6850 and its work fine .
