port mirroring+stop network conectivity
hombrezuelo
Post by hombrezuelo » 04 Apr 2018 13:00
Hi everyone
I'm running OS6850-P48L 6.4.4.342.R01 and I'm facing the following case, I created a port mirroring session with this command:
port mirroring 1 source 1/36 destination 1/14
I got this:
show port mirroring status
Session Mirror Mirror Unblocked RPMIR Config Oper
Destination Direction Vlan Vlan Status Status
1. 1/14 - NONE NONE Enable On
Mirror
Source
1. 1/36 bidirectional - - Enable On
in port 1/14 is connected a PC with linux to t-shoot purposes acting like destination, after port mirroring is enabled the network conectivity get lost and I cannot communicate with the PC in port 1/14. Is there something else that I'm forgetting to do?
Please someone can point me in the right direction to solve this issue?
Thank you.
Jah bless
Re: port mirroring+stop network conectivity
Post by silvio » 05 Apr 2018 01:56
this is at alcatel switches the normal behavior. The destination port is only for mirroring....
hombrezuelo
Post by hombrezuelo » 05 Apr 2018 10:29
Okay I get it. Thank you Silvio.
Kind regards.
