IP helper Snooping
almatel
IP helper Snooping
Post by almatel » 21 Apr 2018 18:24
Hi all,
reference to the attached Network topology :
First:
the configuration is running ok!, but if there is a better idea to improve it , please advise.
Second:
to drop duplicate ip addresses that are coming into the
Dist. switch using dhcp snooping Ip Source Filtering feature do I have to enable it on the the distribution Switch for each vlan:
ip helper dhcp-snooping (for each vlan ) enable
and :
ip helper dhcp-snooping binding enable
ip helper dhcp-snooping port 1/47 trust (DHCP Server)
ip helper dhcp-snooping port 1/46 trust (OXE)
ip helper dhcp-snooping port 1/30 trust (A6450)
ip helper dhcp-snooping port 1/45 trust (stand alone A6850E)
ip helper dhcp-snooping linkagg 2 trust (Stack)
and do the same on ports basis + Enable Ip-source filtering like:
A6850E stand alone switch:
ip helper dhcp-snooping port 1/48 trust
ip helper dhcp-snooping ip-source-filter (for each vlan ) enable
A6450 switch
ip helper dhcp-snooping vlan 2 enable
ip helper dhcp-snooping port 1/24 trust
ip helper dhcp-snooping ip-source-filter vlan 2.
Stack Switches
please advise.
BR
