Can't boot 6850
strelok
Can't boot 6850
Post by strelok »
Hi !
We have problem with booting switch 6850.
Every time boot process stopped at message: /flash/ - Volume is OK
And that's it.
We tried to boot miniboot, but the same situation: booting process stopped at message "/flash/ - Volume is OK"
No any erros in logs.
I attached log from console.
Any ideas, guys ?
Re: Can't boot 6850
to not stop at miniboot you have to change the bootflag back to 0x0.
If than the switch is not loading the AOS-image from certified the image at the flash is missing or corrupt. You have than to go to miniboot again. There you have the possibility to make a recovery. Depending from your hardware and miniboot you can use USB or need Xmodem.....
You will find some post for both ways here in the forum (it is similar for all omniswitches R6).
strelok
Re: Can't boot 6850
Post by strelok »
Hi, Silvio !
I did not notice your answer.
I know about 0x0 flag for coming back to ususal load. The main problem that we can't to get miniboot. When we try to get miniboot after changing flag to 0x1000 we get the same situation: loading stopped at message "/flash/ - Volume is OK". And can't use zmodem.
Also we took out SD CARD from switch and we did not discover any problem with flash. It's correctly work in card-reader.
May be we should re-write AOS on flash using card-reader ?
