802.1x non-supplicant
MJB_CPass
Post by MJB_CPass » 22 Aug 2018 07:02
could anybody offer some advice please.
I am entering "802.1x 1/4 non-supplicant policy authentication pass vlan 50 block fail block"
this is working well but how can I apply this to multiple ports in the same command, or, how can I set this as default.
many thanks in advance...
devnull
Re: 802.1x non-supplicant
Post by devnull » 24 Aug 2018 08:29
I don't think you can set this as default, you have to enter it for all ports manually.
With later AOS7/8 Versions yor could create templates, but afaik not in 6.X
