Updating route map in ospf
mouthpiec
Post by mouthpiec » 28 Aug 2018 04:43
I am trying to add a new subnet into route map named static-to-ospf, but I am getting the following error:
ip static-route 10.10.0.19/32 gateway 10.172.90.90 metric 1
ip route-map "static-to-ospf" sequence-number 10 match ip-address 10.10.0.19/32 redist-control aggregate permit
ERROR: Route Map cannot be modified while in use
Can you please suggest way forward?
Shall I first disable ospf with the following command:
ip redist static into ospf route-map "static-to-ospf" status disable
If that is the case, will the switch stop accepting and sending routes through OSPF?
Re: Updating route map in ospf
Post by silvio » 28 Aug 2018 14:52
disable the redist means that only this static routes will not be distributed into ospf anymore. OSPF (exchange of routes) will work further, and also normal routing will proceed without interrupts.
mouthpiec
Post by mouthpiec » 29 Aug 2018 02:40
thanks for the feedback.
That means if other routers have routes installed through this router, these routes will be removed while the redist is disabled. Am i correct?
Post by silvio » 29 Aug 2018 07:56
No, only this one local route will be disabled - so only this route will be removed from the routing tables.
