6850 P-48 ERP
thekotaksampah
6850 P-48 ERP
Post by thekotaksampah » 05 Sep 2018 02:55
Hi Expert,
I try to configure erp on 6850-P8 chassis. I have detail information about the box as following:
OMNI6850-TEST1# show chassis
Chassis 1
  Model Name:                    OS6850-P48,
  Description:                   48 G POE,
  Part Number:                   902542-90,
  Hardware Revision:             02,
  Serial Number:                 H4686676,
  Manufacture Date:              NOV 22 2007,
  Admin Status:                  POWER ON,
  Operational Status:            UP,
  Number Of Resets:              52
  MAC Address:                   00:e0:b1:85:1c:1c,
OMNI6850-TEST1#
and The software version as following:
OMNI6850-TEST1# show microcode
   Package           Release       Size     Description
Kbase.img         6.3.1.894.R01   14723317 Alcatel Base Software
Kadvrout.img      6.3.1.894.R01    2683964 Alcatel Advanced Routing
K2os.img          6.3.1.894.R01    1733979 Alcatel OS
Keni.img          6.3.1.894.R01    4902136 Alcatel NI software
Ksecu.img         6.3.1.894.R01     475259 Alcatel Security Management
K2diag.img        6.3.1.894.R01    1599866 Alcatel Diagnostic Software
OMNI6850-TEST1#
But, I try to configure the erp. Seems like the configuration is not available. May I have recommendation AOS to enable ERP for OS 6850?
Thank you very much
devnull
Re: 6850 P-48 ERP
Post by devnull » 05 Sep 2018 03:32
I would always try to update to the latest release. ERP is afaik not available in 6.3.1 - i found it in 6.3.4 manual.
Last version for that EOS Devies is 6.4.4 - i'd go for that.
