Reset snmp process
aviviis
Reset snmp process
Post by aviviis » 26 Oct 2018 10:32
Hello
Is there any way to reset only the process of the snmp ? Because when i make an snmpget for some oid i am getting misorder result .
Re: Reset snmp process
Post by silvio » 27 Oct 2018 08:14
there are unsupported commands within the dshell.
"i" shows all your processes, and "td" (task delete) kills a process.
With „ts“ (task suspend) and „tr“ (task resume) you stop and restart one proc.
aviviis
Post by aviviis » 27 Oct 2018 12:56
