Load balance on lag
aviviis
Load balance on lag
Post by aviviis » 08 Nov 2018 11:05
Do you know how the 6850 make load balance on 2 link that configure as a linkagg ?
Base on ip , mac ?
Can i config it to make load balance base on source mac ?
Re: Load balance on lag
Post by silvio » 09 Nov 2018 01:34
in my knowledge the ip will be used if the packet has an ip header. In extended mode the udp/tcp port will be also used. So I don't think that the mac can be used for the decision.
aviviis
Post by aviviis » 09 Nov 2018 15:15
