OS 6850 file system?
yanxiaomin
Post by yanxiaomin » 19 Jul 2009 11:06
Did anyone who know the omniswitch flash file system ?it it Fat32?fat? ntfs? or ext2?or other ?who can tell me how I can format the flash in vxwork mode or in miniboot mode?
yanxiaomin
Re: OS 6850 file system?
Post by yanxiaomin » 20 Jul 2009 00:59
May I use the "erase" to format the flash ?
? - alias for 'help'
autoscr - run script from memory
base - print or set address offset
bdinfo - print Board Info structure
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BootP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
cmp - memory compare
coninfo - print console devices and informations
cp - memory copy
crc32 - checksum calculation
diskboot- boot from IDE device
echo - echo args to console
erase - erase FLASH memory
fatdelete - delete a file from a fat filesystem
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatwrite - write binary file to a fat filesystem
flinfo - print FLASH memory information
go - start application at address 'addr'
help - print online help
icrc32 - checksum calculation
ide - IDE sub-system
iloop - infinite loop on address range
imd - i2c memory display
iminfo - print header information for application image
imls - list all images found in flash
imm - i2c memory modify (auto-incrementing)
imw - memory write (fill)
inm - memory modify (constant address)
iprobe - probe to discover valid I2C chip addresses
itest - return true/false on integer compare
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
md - memory display
mm - memory modify (auto-incrementing)
mtest - simple RAM test
nfs - boot image via network using NFS protocol
pci - list and access PCI Configuraton Space
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sleep - delay execution for some time
tftpboot- boot image via network using TFTP protocol
usb - USB sub-system
usbboot - boot from USB device
version - print monitor version
cedric1
Post by cedric1 » 21 Jul 2009 04:57
hello
In miniboot mode
type ioHelp
you have command to format flash and file system.
Cedric
yanxiaomin
Post by yanxiaomin » 23 Jul 2009 06:59
Thanks. after I format the flash and upload the image files the 6850 run normal .but it when NI up it output in consle.
I use 126W power.
logs :
THU JUL 23 14:47:33 : LANPOWER (108) info message:
+++ lpGetMaxPorts: invalid NI Type 42012214 Slot 1 ERROR!!
cedric1
Post by cedric1 » 23 Jul 2009 10:07
hi
did you try to launch command lanpower start 1
did you get an error ?
Did you have power feeding or not ? connect Wifi AP or a phone to check
Cedric
benny
Post by benny » 01 Aug 2009 05:41
The 126W AC power-supply doesn't support PoE. You need the 360W or 510W variant.
P.S. Kindly stop to post your question several times. Thanks.
-benny
Benny
cedric1
Post by cedric1 » 03 Aug 2009 07:26
hi yanxiaomin
Why did you use a P24 switch with a 126W.
Normally when you order a POE switch you can only choose between 360 or 510 Watts.
cedric
yanxiaomin
Post by yanxiaomin » 05 Aug 2009 06:40
thanks .there was something wrong with my 360W power,and I sended it to alcatel. when I poweroff the switch's lanpower it was normal now!
lmherdvera
Post by lmherdvera » 24 Dec 2016 08:55
Please Help..how can I delete the missed type configuration..
Thank you in very much...
=> printenv
bootargs=
bootcmd=run miniboot
bootdelay=1
loads_echo=1
ipaddr=192.168.10.1
serverip=
rootpath=
gatewayip=
netmask=255.255.255.0
hostname=OS68xx
bootfile=
loadaddr=0x1000000
serialmode=modemControlOff
----------------------------------> bootfalgs=0x1000
----------------------------------->booflags=0x0
----------------------------------->baurate=115200
bootflags=0x1000
baudrate=115200
stdin=serial
stdout=serial
stderr=serial
miniboot=bootm 0xff900000
osboot=run miniboot
ramsize=0x20000000
Environment size: 385/8188 bytes
Post by silvio » 26 Dec 2016 05:18
this wrong entries should do not issue in your switch. But you can try to reset all.
Try "purge" or "purgeenv" - I'm not sure if this command will be supported at 6850.
But you can also delete the file bootparams and restart the switch.
Than the default settings will be used.
