Problem with boot omniswitch OS6400 P48
elholandes
Post by elholandes »
Hello!
I have a problem with boot OS 6400 p48:
The problem is the same:
When the sorce is on the led pwr becomes green and the led on constantly flashing yellow
I use the console port and the switch shows:
U-Boot (6.3.4.265.R01) (for OS6400, OS6850, and OS6855 platforms) (Dec 15 2008 - 21:31:42)
MPC8247 Reset Status: External Soft, External Hard
MPC8247 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8247 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS6400 (Garuda)
I2C: ready
DRAM: 256 MB
After this message, the switch doesn t work and hangs in this state
What is the problem???
The u-boot?
Please can help me?
Thanks!
elholandes
Re: Problem with boot omniswitch OS6400 P48
pleaes.. can help me?
With your old release 6.3.4 you can't use usb recovery (it startet with 6.4.3). So you have to recover your switch via serial (using zmodem). I attache a document. it will take a long time to send the new images-files via zmodem. But it is the onliest way if the flash is corrupt. Also you will find similar tips in other forums here - it is the same way like at 6850 for example.
elholandes
Hi silvio:
Thanks!!!
I have recover via serial and y use putty program, this program freezes in this message.. but.. how i can recover the switch?
The exactly question is the same:
-I use putty program setting:
serial interface
baud rate: 9600
How configurate putty to passes step 1 and 2 the document???
Beste regards!
devnull
Post by devnull »
If you switch stucks before it is possible to enter uboot i would RMA it.. tha 6400 should have lifetime waranty, so you should get a new one.. ask your reseller/Distri
elholandes
My question is because the switch havent warantry.... Please.. who solve this problem???
mnehar
Post by mnehar »
Hi here I have a problem with my poe switch Alcatel 6850 48 Ports is that we I activate POE with the command lan power start 1 I have an error message displayed
-> Lanpower start 1
THU 17 December 11:02:14: SYSTEM (75) alert message:
+++ I2cPoEReadReg: Unable to Read PD640xx I2C device 0x60
THU 17 December 11:02:14: LANPOWER (108) error message:
+++ SysReadPD690xx: i2c Read Failed !!
+++ Pd69_lpSysGetHWStatus: Invalid read!
+++ Unable to get HW Status pd69_lpStartNI
THU 17 December 11:02:22: SYSTEM (75) info message:
+++ The Port ID Causing i2c Bus Lockup is0
THU 17 December 11:02:22: SYSTEM (75) alert message:
+++ I2cReadOnBoardTemp: i2cRandomRead ERROR Temp Sensor = 0x96
THU 17 December 11:02:22: PRB-CHASSIS (102) error message:
+++ Error reading temperature sensor
so I can say it is a problem with AOS I proceed to upgrade to the
6.4.6.278.R01 Service Release, May 19, 2015 still the same problem
Thanks for your help
mnehar
Re: Problem with POE OS 6850-48P
Post by mnehar »
-> Lanpower start 1
mnehar
Post by mnehar »
can you help me ??? I have a lo tof switchs affected by this problem
elholandes
Hello Silvio
I now the same problem but now its becomes in
Miniboot->
but i cant pass the archives trought Zmodem ( i set the switch in receive mode to sysStartZmodem command ) but i dont know how pass thge images ( can you pass me the fiwmware for os 6400? i only encou8ntred os 6850 firmware)
This switch was set the led in "1" but the led on becomes flashlight and the mnessage is:
cant download XXXXX abort
The memoryy is corrupt, i entered in miniboot mode but :
serial interface
baud rate: 9600
Beste regards!
Return to “OmniSwitch 6400”
