OMNISTACK 6200 VLAN´S WITH QoS
mramirezg
Post by mramirezg »
170_OS6200_QoS.pdf
Hi, we have a 6248P, we have 2 Vlan´s, one for voice (vlan3) and another for data (vlan 2), we configured the switch according to a file we found on the web (I´m attaching it) with qos, the pbx is an OXO with IP Touch, when we configured the switch the pbx and the phones are working ok with static ip´s, but the PC who is behind the IP touch is not working neither with static ip nor with dhcp. Also the phones are working with static ip´s but not with dhcp. I´m attaching the network topology.
Mauricio
Return to “OmniStack LS 6200”
