6200 VLANS WITH QoS
mramirezg
6200 VLANS WITH QoS
Post by mramirezg »
Hi, we have a 6248P, with 2 Vlan´s, one for voice and another for data with qos, the pbx is an OXO with IP Touch, when we configured the switch the pbx and the phones are working ok with static ip´s, but the PC who is behind the IP touch is not working neither with static ip nor with dhcp. Also the phones are working with static ip´s but are not with dhcp
Here is the configuration on the 6248
vlan database
vlan 2-3
exit
interface vlan 2
name data
exit
interface vlan 3
name voice
exit
interface ethernet e2
switchport mode trunk
switchport trunk native vlan 2
switchport trunk allowed vlan add 3
mac access-list "ACLvoice"
permit any any vlan 3
mac access-list "ACLData"
permit any any
qos advanced
class-map "VoiceClass"
match access-group "ACLvoice"
class-map "DataClass"
match access-group "ACLData"
policy-map "VOIP"
class "VoiceClass"
set queue 4
exit
class “DataClass”
service-policy input "VOIP"
ges8888
Post by ges8888 »
You can try the below commands. The IP phone is able to get DHCP ip, but not PC. So this solution will only solve IP phone portion. Any expert can advise on how to fine-tune the config to allow PC to grab IP add from DHCP server? Thanks.
vlan database
map mac 00:80:9f:00:00:00 24 macs-group 3
interface ethernet e1
switchport general allowed vlan add 2
switchport general allowed vlan add 3
switchport general map macs-group 3 vlan 3
exit
mramirezg
Post by mramirezg »
Thanks for the info, I hope someone can tell us how to solve the dhcp for the pc´s
Return to “OmniStack LS 6200”
