Omnistack 6224 and 6248
creep
Post by creep »
I am trying to do port scans from a management server on all my 6200 series switches (320 in all).
I set up SNMP and use the correct snmp community strings on both the switches and the server and when I initiate the port scan then it fails and I get the following message on the console of my switch: Access attempted by unauthorized NMS.
My 6800 switches work fine.
Please help.
cedric1
Post by cedric1 »
hi
here exemple of snmp config
snmp-server engineID local 80001956030012cf821400 --> is automatic generate via command (look in doc for engineID)
snmp-server location bureau
snmp-server contact Team
snmp-server community community_name rw 172.30.0.30 view DefaultSuper --> ip of snmp station
snmp-server host 172.30.0.30 community_name traps 2 -- idem a below
Return to “OmniStack LS 6200”
