Dear All I need help regarding following configuration below. I have posted show version of switch. Switches series is LS6224. I will post show run of switch tomorrow
console# show version
SW version 1.5.1.7 ( date 26-Feb-2008 time 17:04:09 )
Boot version 1.0.0.12 ( date 19-Oct-2006 time 09:07:37 )
HW version 00.00.01
How to Configure SNMP???
Is it possible to configure Inter Vlan Routing on LS 6224?
How to make interface to its default configuration???
Creating Trunks on 6224 Switch???
Verifying trunks???
Configuring GVRP???
Configure AMAP???
Help Required for Configuration
Re: Help Required for Configuration
console# show running-config
interface ethernet e24
switchport mode trunk
exit
I am not able to propogate vlan on 6850 Switch to 6224 Switch even though I enabled GVRP on both Switches
I am not able to ping 6850 Switch VLANs "IP 172.16.x.x" from 6224 Switch
Check 6224 and 6850 Configuration and let me know what I am missing any help in this regard is highly appreciated
6224 Config
vlan database
vlan 10,20,30,40
exit
gvrp enable
exit
interface vlan 1
ip address 192.168.1.20 255.255.255.0
exit
6850 Config
-> show configuration snapshot
! Stack Manager :
! Chassis :
system name vxTarget
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
vlan 10 enable name "VLAN 10"
vlan 10 port default 1/1
vlan 20 enable name "VLAN 20"
vlan 20 port default 1/2
vlan 30 enable name "VLAN 30"
vlan 30 port default 1/3
vlan 40 enable name "VLAN 40"
vlan 40 port default 1/4
vlan registration-mode gvrp
gvrp
! VLAN SL:
! IP :
ip service all
ip interface dhcp-client vlan 1 ifindex 1
ip interface "vlan_10" address 172.16.1.1 mask 255.255.255.0 vlan 10 ifindex 2
ip interface "vlan_20" address 172.16.2.1 mask 255.255.255.0 vlan 20 ifindex 3
ip interface "vlan_30" address 172.16.3.1 mask 255.255.255.0 vlan 30 ifindex 4
ip interface "vlan_40" address 172.16.4.1 mask 255.255.255.0 vlan 40 ifindex 5
! IPX :
! IPMS :
! AAA :
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Link Aggregate :
! Port Mapping :
! VLAN AGG:
! 802.1Q :
vlan 10 802.1q 1/24 "TAG PORT 1/24 VLAN 10"
vlan 20 802.1q 1/24 "TAG PORT 1/24 VLAN 20"
vlan 30 802.1q 1/24 "TAG PORT 1/24 VLAN 30"
vlan 40 802.1q 1/24 "TAG PORT 1/24 VLAN 40"
! Spanning tree :
bridge mode flat
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! Server load balance :
! System service :
exit
6224 Config
vlan database
vlan 10,20,30,40
exit
gvrp enable
exit
interface vlan 1
exit
6850 Config
! Stack Manager :
! Chassis :
! Configuration:
! VLAN :
gvrp
! VLAN SL:
! IP :
ip service all
! IPX :
! IPMS :
! AAA :
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Link Aggregate :
! Port Mapping :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode flat
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! System service :
