OS 6200 password issue
stunshot
Post by stunshot » 28 May 2015 07:04
Hi all, have lost telnet/ssh access to an old 6200... can get on via http, anyway to reset telnet password from GUI ??
Cheers
Re: OS 6200 password issue
Post by cavagnaro » 28 May 2015 09:15
Console cable?
stunshot
Post by stunshot » 28 May 2015 09:21
Hi cavagnaro, yes but its a remote support job so want to avoid this....
Post by cavagnaro » 28 May 2015 09:35
Imagine yourself as a hacker...do you think Alcatel would provide such easy way and if possible us to make it public available?
stunshot
Post by stunshot » 28 May 2015 10:17
Indeed, but I have just been on via url and found that I could reset it, tried it and back in via telnet... as I only ever use CLI is why i asked the question, as you say this is a security hole unless you disable http/https...
Return to “OmniStack LS 6200”
