Problem of disconnecting communications
iaf41
Post by iaf41 » 30 Sep 2016 04:05
I have new OmniStack LS 6224 i update is firmware to "OS6200_v1.7.1.12"
But I have a problem with it
Every randomly time period
Communication to Some of computers disconnected
Communication resumes only if I disconnect the computer network cable and connect it again
Other computers on the network remain unchanged (In other words there is communication)
the computers from which Communication is disconnects are random
what could be the problem ???
Re: Problem of disconnecting communications
Post by silvio » 30 Sep 2016 13:31
"new" LS6224???? This switch has end of sales a lot of years ago (8 or 9). So you have a very old switch :(
What have you tested until now? changed working with not working device? checked port status (autoneg, full or half)? Show all devices at the 6224 the same behavior? Or is there one computer that works normal? What did you mean with randomly period? Does it work for some days and than the issue occours?
Silio
iaf41
Post by iaf41 » 01 Oct 2016 14:01
the Switch is new
There were a few new pieces packed
In a warehouse I had to clean up
Unfortunately I have no knowledge of the systems technician
So I do not know what tests to do
Or what do you mean
no
As soon as I disconnect the network cable and re-connect device
He returns to work properly
no
how do i do that ?
yes
It does not matter which port they are connected
yes
For example, in the last two days There was no problem
I have 4 computers are connected
Occasionally there is a communication problem
And the way to solve it
Disconnect the network cable of the computer with the problem
And connect it again
The problem does not affect other computers
There have normal communications, (Internet Services )
Post by silvio » 06 Oct 2016 18:07
show interfaces status (in case of failure).
Maybe driver/NIC problem at the computers?
iaf41
Post by iaf41 » 13 Oct 2016 04:10
where is interfaces status ?
Post by silvio » 14 Oct 2016 02:43
with serial connection direct at the switch....
Return to “OmniStack LS 6200”
