Perform TDR via snmp
Locked
supafly
Post by supafly »
Is there any method to perform cable test via snmp? OIDs that I found are not working. Please help :-?
Re: Perform TDR via snmp
Are you familiar with OSI layer?
supafly
Post by supafly »
Yes. What do you mean?
supafly
Post by supafly »
UP
supafly
Post by supafly »
There is a way to perform cable diagnostic via snmp on d-link switches with number of OIDs specified for that. Does os 6200 have same functional?
supafly
Post by supafly »
I found that linxys oids are working well
Check is port ready for test:
snmpwalk [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.1.1.1.$port
1-yes 2-no
launch test:
snmpset [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.1.1.1.$port i 2
What port can return
snmpwalk [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.2.1.1.$port
1.3.6.1.4.1.89.90.1.2.1.1.$port.2 2
1.3.6.1.4.1.89.90.1.2.1.1.$port.3 3
rlPhyTestTableCableStatus(2),
rlPhyTestTableCableFault(3),
Test status
snmpwalk [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.2.1.2.$port
1.3.6.1.4.1.89.90.1.2.1.2.$port.2 2
1.3.6.1.4.1.89.90.1.2.1.2.$port.3 2
{none(1), success(2),inProgress(3),notSupported(4),unAbleToRun(5), aborted(6),failed(7)}
Test result
snmpwalk [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.2.1.3.3
1.3.6.1.4.1.89.90.1.2.1.3.$port.2 4 result
4_pair_cable(1), 2_pair_cable(2), no_cable(3), open_cable(4), short_cable(5), bad_cable(6), impedance_mismatch(7)
1.3.6.1.4.1.89.90.1.2.1.3.$port.3 53 cable length
last test time
snmpwalk [OPTIONS] 172.*.*.* 1.3.6.1.4.1.89.90.1.2.1.6.$port
1.3.6.1.4.1.89.90.1.2.1.6.$port.2 "10-Jun-2016 07:37:46 "
1.3.6.1.4.1.89.90.1.2.1.6.$port.3 "10-Jun-2016 07:37:46 "
close topic please
Locked
Return to “OmniStack LS 6200”
