Time source is sntp (error)
gladispaola
Post by gladispaola »
hI guys,
I have switch OmniStack LS 6224P. I need repair clock right.
At the moment configuration is :
clock timezone -2
clock source sntp
sntp unicast client enable
sntp server 10.30.0.13 poll
sntp server 10.30.0.10 poll
no ip domain-lookup
# sh clock
.16:24:31 (UTC-2) Aug 23 2017
Time source is sntp
I should is 17:24:31, time o'clock.
# show sntp configuration
Polling interval: 1024 seconds.
No MD5 authentication keys.
Authentication is not required for synchronization.
No trusted keys.
Unicast Clients: Disabled
Unicast Clients Polling: Disabled
Server Polling Encryption Key
172.17.29.89 Disabled Disabled
Broadcast Clients: disabled
Anycast Clients: disabled
No Broadcast Interfaces.
i set sntp server, but i need Authentication key. i put on key 2?
(config)# sntp server 172.17.29.89 poll key 2
i don't know why key 2 or what key put on.
i find a example in other forum :
"  Set the server authentication key identification number using thekeyword. This key identification number must be the one the server uses for MD5 encryption. For exam-ple, to specify key identification number 2 for an NTP server with an IP address of 1.1.1.1, enter:-> ntp server 1.1.1.1 key 2
Then, i polling chance from "disable" for "enable" exibit next:
No trusted keys.
Unicast Clients Polling: Enabled
172.17.29.89 Enabled 2
but time o'clock continue is wrong.
(config)# clock timezone
(config)# exit
# sh clock
.20:21:31 (UTC+0) Aug 23 2017
Time source is sntp
i needed put on timezone -3, but i need put on sntp server.
(config)# clock timezone -3
(config)# exit
# show clock
.17:24:52 (UTC-3) Aug 23 2017
Time source is sntp
#sh version
SW version 1.7.0.13 ( date 23-Oct-2008 time 12:12:55 )
Boot version 1.0.0.12 ( date 19-Oct-2006 time 09:07:37 )
HW version 00.00.01
Return to “OmniStack LS 6200”
