Omnistack 4024
bancroa
Omnistack 4024
Post by bancroa »
I have purchased a second hand Omnistack 4024 and am having the following booting problem
it seems the img file is corrupt. Can anyone help me?
Andrew
Log-file
[INDENT]auto-booting...
Boot device : ffs
Boot file : /flash/mp4.img
Startup script : /flash/mp4.cmd
Console params : 9600,n81c
Modem params : 9600,n81
Boot flags : 0xb
Other : dvip:no-name,192.168.10.1,255.255.255.0,192.168.10.255;
Loading /flash/mp4.img...
Cannot open "/flash/mp4.img".
Error loading file: errno = 0x2.
Halting system, please wait...
Flash file system check in progress...
Checking root file system... OK
Performing file consistency check...
Done.
FFS Id:1d5 Sectors:16 Size:4194304
Bootline configuration not set, using default values
System Boot
Press any key to stop auto-boot...
[/INDENT]
benny
Post by benny »
Hi Andrew,
The one who owned the device before deleted the operating system. You'll need to find the XOS (Xylan Operating System) and upload it via Zmodem.
-benny
Benny
bancroa
Post by bancroa »
Thanks Benny
Where can I pick up the OS?
ANdrew
cedric1
Post by cedric1 »
did you get the os ?
bancroa
Post by bancroa »
I have surfed the web and cannot seem to find anywhere I can get the OS.
Can anyone else help?
Andrew
walcycarroll
Post by walcycarroll »
I see your post was quite awhile ago, but let me know I may have a copy of the AOS for the device.
marcvs
Post by marcvs »
@walcycarroll
I have the same problem like in this thread!
Could you help me, please?
Marcus
mart
Re: Omnistack 4024
Post by mart »
Found a firmware maybe, take a look at this link...
https://service.esd.alcatel-lucent.com/ ... Omni_Stack
but i got no idea how to upgrade it...
Return to “Legacy Devices (OS4024, XOS, OmniCore)”
