i have two OAW 4604 in VRRP Master-Master Redundancy.
OAW 1:
VLAN 1 IP 10.0.0.102 (Loopback 10.0.0.104)
VRRP ID 5 Prio 110
OAW 2:
VLAN 1 IP 10.0.0.103 (Loopback 10.0.0.105)
VRRP ID 5 Prio 100
VRRP IP 10.0.0.101
Redundancy function works, but if i connect wireless (AP125) to the network and ping the gateway 10.0.0.1, i habe some timeouts in case of redundance takeover.
is this right?
is a time out in vrrp ok?
OAW 4604 Master-Master Redundancy
Alf
Alf
Re: OAW 4604 Master-Master Redundancy
Sorry for "reopening" this topic.
Since in network you have 2 wireless controllers OAW 4604 are they doing someking of synchronization? From AP's poing of view there is only on controller with IP address 10.0.0.101 (VRRP virtual address).
But what is about controller's view? Do you have to configure user profiles and other settings on both controllers or just on one (and then to give synchornization from one controller to another one)?
I suppose that if redundancy is needed only option is to have 2 controllers in network?
regards,
nikolami
regards,
nikolami
The redundance from AP view is that there is only one master (or local) ip = VRRP virtual address.
You have to configure at the "backup master" only the wired network (with vrrp and vrrp priority) and the ip of the "active master".
All other configs you do at the active master. It will synchronice both databases in case of changes.
regards Silvio
regards Silvio
This means that 2 wireless controllers work in "active-standby" mode. After secondary controller becomes active it already has valid (synchronized) configuration.
regards,
nikolami
regards,
nikolami
