7360 ISAM FX-16 login
wii
Post by wii »
Hello all,
Does anyone know what's the default login for this system? I've tried admin/admin, root/admin, admin/switch, and none of them worked. I'm also looking for a guide for the CLI and I coudn't find them any where. Thank you in advance.
Would you like a CLI(C) or a TL1 login(T) or TL1 normal session(N) ? [N]:
Would you like a CLI(C) or a TL1 login(T) or TL1 normal session(N) ? [N]: c
login:
Connection closed
login: root
password:
Login incorrect
login: admin
password:
Login incorrect
login: superuser
password:
Login incorrect
Connection closed
This terminal is locked for 2 minutes
This terminal is locked for 1 minutes
The terminal is unlocked
?X
/* COMMAND INPUT RESET */
?X
/* HELP MENU
HELP or ? Type HELP or ? for this menu.
MENU Type MENU for menu mode.
<UP ARROW> or '^B' Recall previous commands.
<DOWN ARROW> or '^N' Recall successive commands.
<LEFT ARROW> or '^D' Move cursor left one space.
('^D' Teminate Telnet session).
<RIGHT ARROW> or '^F' Move cursor right one space.
'^E' Move cursor to end of line.
'^A' Move cursor to start of line.
<CAN> or '^X' Reset command input processing.
<BS> or '^H' Delete previous input character.
<DEL> Restart current line input. */
< menu
ALCATEL-LUCENT Telecom
Command Menu
1. MAINTENANCE
2. PROVISIONING
3. SECURITY
4. TEST
Select (1-4):
Chirs
Re: 7360 ISAM FX-16 login
Post by Chirs »
HI i was wondering if you maybe able to assist on a similar issue I am trying to login to ISAM 7302 node with CLI and have no access do i need special cable or software for this?
Return to “OmniAccess WLAN Switching Systems (OEM)”
