Oaw 4306gw
maxmania
Oaw 4306gw
Post by maxmania » 14 Feb 2017 19:10
Hi everyone,
I got a oaw4306gw, but i can't use the internal AP. Any tips?
Best Regards
Jose Alves
Re: Oaw 4306gw
Post by silvio » 15 Feb 2017 02:23
Since some years the the internal AP is deactivated. Max number of AP's are now 16 instead 16+1. I'm not sure about the release where this limitation where released.
maxmania
Re: Oaw 4306gw
Post by maxmania » 15 Feb 2017 14:13
HI Silvio,
from the Alcatel website:
"After upgrading the OAW-4306GW to 6.3.x The internal AP was not working."
I have downgraded to AOS-W 6.2.1.8, but still not working!!!
during the boot you can see the wifi board is there.
I have tried to get the firmware from Aruba website (651) , but I can't get it!!
Best Regards
Jose Alves
maxmania
Re: Oaw 4306gw
Post by maxmania » 15 Feb 2017 15:23
After some testes I discover this, the Internal Ap will only work with AOS-w 6.1.X . Earlier version (6.2.x ) disable the internal AP.
Best Regards
Jose Alves
maxmania
Re: Oaw 4306gw
Post by maxmania » 15 Feb 2017 15:24
Best Regards
Jose Alves
Return to “OmniAccess WLAN Switching Systems (OEM)”
