I am getting below result via telnet IP@ telephone/ config command.
What is the difference between Current and Flash and how can I change FLASH configuration??
Thanks i n advance
For one extension current and Flash values are
config CURRENT
dhcp mode : dynamic
ip addr : 10.233.97.59
subnet mask: 255.255.255.0
router addr: 10.233.97.2
tftp addr 0: 194.4.112.125
tftp addr 1: 255.255.255.255
tftp_backup: 10.233.97.7
tftp port : 69
main cpu 0 : 194.4.112.125
main cpu 1 : 255.255.255.255
main port : 69
VLAN : 100 (0x64)
use VLAN : yes
strict VLAN: yes
boot mode : full
port lan : 100/full
port pc : no link
init mode : 0x0 (none)
phy addr 1 : 194.4.112.126
phy addr 2 : 194.4.112.124
cust (val) : <invalid>
cust (req) :
L10N (val) : <invalid>
L10N (req) :
