Has anyone been able to get a 56K USB modem working from a Win7 64 bit laptop. Model is AM5067. See attached userguide for list of commands.
I try an establish a a XRA connection to customer site with common hardware GD3 at the remote site for maintenance purposes.
The modem dials and tries to negotiate and then drops the call as when normally this is the part when the eRMA login appears. I can access system from a laptop using same line with an XP machine with built in modem or other external modems from other vendors.
Have tried to use AT commands but this modem does not support the No carrier command. It just may be that its not compatible for XRA connections to an OXE or OXO.
The usual setup has been testing with 9600 port speed, data protocol set to Standard EC, Compression Enabled and Flow Control set to None from the terminal end.
Log files from the Modem in device manager shows as follows.
06-29-2016 12:53:34.629 - File: C:\Windows\system32\tapisrv.dll, Version 6.1.7601
06-29-2016 12:53:34.629 - File: C:\Windows\system32\unimdm.tsp, Version 6.1.7601
06-29-2016 12:53:34.629 - File: C:\Windows\system32\unimdmat.dll, Version 6.1.7601
06-29-2016 12:53:34.629 - File: C:\Windows\system32\uniplat.dll, Version 6.1.7600
06-29-2016 12:53:34.645 - File: C:\Windows\system32\drivers\modem.sys, Version 6.1.7600
06-29-2016 12:53:34.645 - File: C:\Windows\system32\modemui.dll, Version 6.1.7600
06-29-2016 12:53:34.645 - File: C:\Windows\system32\mdminst.dll, Version 6.1.7600
06-29-2016 12:53:34.645 - Modem type: LSI USB 2.0 Soft Modem
06-29-2016 12:53:34.645 - Modem inf path: oem72.inf
06-29-2016 12:53:34.645 - Modem inf section: LSI_USB
06-29-2016 12:53:34.645 - Matching hardware ID: usb\vid_047e&pid_2892
06-29-2016 12:53:35.144 - 115200,8,N,1, ctsfl=1, rtsctl=2
06-29-2016 12:53:35.144 - Initializing modem.
06-29-2016 12:53:35.160 - Send: AT<cr>
06-29-2016 12:53:35.160 - Recv: AT<cr>
06-29-2016 12:53:35.160 - Command Echo
06-29-2016 12:53:35.160 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.160 - Interpreted response: OK
06-29-2016 12:53:35.175 - Send: AT &F E0 &C1 &D2 V1 S0=0\V1<cr>
06-29-2016 12:53:35.191 - Recv: AT &F E0 &C1 &D2 V1 S0=0\V1<cr>
06-29-2016 12:53:35.191 - Command Echo
06-29-2016 12:53:35.191 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.191 - Interpreted response: OK
06-29-2016 12:53:35.207 - Send: ATS7=60S30=0L2M1\N3%C1&K3N1\J1X4<cr>
06-29-2016 12:53:35.222 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.222 - Interpreted response: OK
06-29-2016 12:53:35.222 - 9600,8,N,1, ctsfl=0, rtsctl=1
06-29-2016 12:53:35.222 - Initializing modem.
06-29-2016 12:53:35.238 - Send: AT<cr>
06-29-2016 12:53:35.238 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.238 - Interpreted response: OK
06-29-2016 12:53:35.253 - Send: AT &F E0 &C1 &D2 V1 S0=0\V1<cr>
06-29-2016 12:53:35.253 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.253 - Interpreted response: OK
06-29-2016 12:53:35.269 - Send: ATS7=60S30=0L2M1\N3%C1&K0N1\J1X4<cr>
06-29-2016 12:53:35.269 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:53:35.269 - Interpreted response: OK
06-29-2016 12:53:35.269 - Dialing.
06-29-2016 12:53:35.285 - Send: ATDT#########<cr>
06-29-2016 12:54:05.384 - Attempting to abort current command
06-29-2016 12:54:05.384 - Send: <cr>
06-29-2016 12:54:05.694 - Recv: <cr><lf>NO CARRIER<cr><lf>
06-29-2016 12:54:05.694 - Interpreted response: No Carrier
06-29-2016 12:54:05.694 - Hanging up the modem.
06-29-2016 12:54:05.704 - Send: ATH E1<cr>
06-29-2016 12:54:05.714 - Recv: <cr><lf>OK<cr><lf>
06-29-2016 12:54:05.714 - Interpreted response: OK
06-29-2016 12:54:05.714 - Session Statistics:
06-29-2016 12:54:05.714 - Reads : 38 bytes
06-29-2016 12:54:05.714 - Writes: 0 bytes
Netcomm USB56K USB Modem XRA dialling issue Model AM5067
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ VMWARE
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ DIALER
- ↳ VM_BACKUP
- ↳ ipview analyzer
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ infocollect
- ↳ motview
- ↳ Other Alcatel-Lucent tools
- ↳ OFFICIAL TC's
- ↳ sngrep
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
