script to change 4645AA
fery_s
Post by fery_s » 11 Mar 2018 00:50
hello everybody
i'm going to write an script to change make some change with "mgr -nodico " in specific time, all of my change in different menu is correctly done but when i try to make some changes in 4645AA it does not success. here is my script that i put in a file with name AA:
SET Embedded_VM_AA "1": "1": "1": "2015"
PreConfigured_Number_For_Default = "2017"
and here is the error when i run "mgr -nodico -X AA:
ooo Starting at <10/03/18 20:32> ...
ooo Compiling Command file "/DHS3bin/mtcl/a" ...
!!! Command : file "/DHS3bin/mtcl/a", line 4
!!! Operation : SET
!!! Object Name : Embedded_VM_AA
!!! : 1
!!! : 1
!!! : 1
!!! : 2015
!!! Operation : SET
!!! : 1
!!! : 1
!!! : 1
!!! : 2015
CMISERR_5
ooo Job completed. at <10/03/18 20:32> ...
it seems "Embedded_VM_AA" object is unknown.
doese anybody has any suggestion ?
alexeik
Re: script to change 4645AA
Post by alexeik » 12 Mar 2018 04:32
have you written the script manually? or recorded it with "mgr -line"?
fery_s
Post by fery_s » 12 Mar 2018 04:41
alexeik wrote:
12 Mar 2018 04:32
hi and thanks for your response
i get the output of mgr -log
alexeik
Post by alexeik » 12 Mar 2018 05:12
hmm strange...
but your right -line was something else...
alex
Post by alex » 12 Mar 2018 06:43
Did you use option "-nodico" with "-log"?
fery_s
Post by fery_s » 12 Mar 2018 08:52
alex wrote:
12 Mar 2018 06:43
yes alex , i use both , with and without -nodio, out put is the same.
and also i test it in another system with different release, problem is occur again
alex
Post by alex » 15 Mar 2018 07:11
Looks like it is not possible to modify VM directory number when you have messages in MB or AA configured.
Return to “Usefull commands”
