AP 225 ping down to Interface 0.
Also known as OmniAccess Instant AP
davidrunciman
Post by davidrunciman »
Hello, i'm having a bit of a trouble with an AP225. We have already configured the one that is going to be the wireless controller, there's one device that it has a valid ip address, i connect it to an alcatel switch (Poe enabled). Even though it has an ip address, it doesn't respond to ping queries and obviously it cannot be reached throught the web interface.
Is there anything i'm missing?
The other devices were configured the same way and it doesn't gave much trouble.
Re: AP 225 ping down to Interface 0.
Only IAP225 has a web ui (if still in instant mode). Have you used the serial console of the AP during boot up? mostly you will see the reason there.
davidrunciman
The interface became available after a reboot. Thanks Silvio for your answer.
Return to “OmniAccess Wireless Access Points”
