I am having a problem with OAW IAP103.
When I start AP with default config everything starts correctly. After complete boot led status is PWR=Solid Green, ENET=Solid green, 5GHz=Solid orange, 2.4GHz=Solid green. I can see and connect to default SSID "instant".
As soon as I change country (from admin web UI or console) I loss conection and 2.4GHz led goes to Solid orange. The AP stays in this state upto it is reset to default.
It seems to work for some country. For example i set GB and the issue does not appear.
I have already upgrade to latest firmware but the problem remains.
Any idea???
Regards.
IAP103 - Network down when defining country
Re: IAP103 - Network down when defining country
you should open a ticket at Alcatel. Which country did you choosen? Maybe someone can test it at an other IAP.
I also having same issue 2 num of IAP 103.
I choose India, Sri lanka China, Maldives .
Thank You,
Akila Madushan.
Akila Madushan.
Thank You,
Akila Madushan.
Akila Madushan.
Hi L_lefante,
I am new in Alcatel-Lucent Data.
I have 2 IAP 103, and want to install without using any WLAN Controller or Switch. I have just 1 L3 switch (OmniSwitch 6860E) and 2 IAP 103.
Please let me know how i'll install and configure these 2 IAPs independently (without using any WLAN Controller or Switch)?
When i power up IAP 103 then after booting up, it shows the SSID "Instant" in Wifi, i connect it and using http:/instant.alcatel-lucent.com on Web Browser to access AP. It shows the connected AP, after 1min it shows registration issue and disconnected. After 1min it does not show "Instant" in Wifi.
Please help me in this regard.
Kind Regards,
Kind Regards,
What country did you set in the first place?
