Hello guys,
I have a AP175 OAW Alcatel-lucent with two radios. The data link is via its Ethernet port. I wonder if I can configure both radios to work as to spread coverage area in the frequency of 2.4 Ghz, with sectoral and hominidirecional antennas?
Thanks,
Luiz
Configuration 2 radios AP175 to works 2.4Ghz
- cavagnaro
Re: Configuration 2 radios AP175 to works 2.4Ghz
http://www.securewirelessworks.com/Aruba-AP-175.asp
According to this specs you should.
Enviado de meu C6602 usando Tapatalk
this setting to work in 2.4GHz radios is made by offering access via WEB or Omnivista need the software to make this change? WEB does not have the option to force the radio work in 2.4.
Thanks,
Luiz
Thanks,
Luiz
Hello, this is a simple (attahed file) configuration I need... if possible, i know if this configuration to radio works or no?
Thanks,
Luiz
Thanks,
Luiz
- cavagnaro
I think experience on that is low, better open an eSR with ALU to clarify doubts
In my knowledge this isn't possible. Also I think that ALU support will not help for this question. But try it out...
