İp touch 4018 change number
hi. I'm using the central OmniVista 4760i. I have 4018 IP Touch phones.16100 internal group. How do I change the phone's internal number.
please answer
thanx
please answer
thanx
- cavagnaro
Re: İp touch 4018 change number
You can't. You create another extension only and delete old one.
Sent from my XPeria Z
I tried to delete. but it gives error.
> Delete \dinarsu_alapli\Users::16104
Forbidden: station supervised by attendant
Forbidden: station supervised by attendant is the answer, go into the supervison keys of the attendant and remove the supervision!!!
How can i do ? can you write me pleaseoldboy wrote:Forbidden: station supervised by attendant is the answer, go into the supervison keys of the attendant and remove the supervision!!!
have you got 4760 ?
yes i have got 4760. and İ have 4018 ip touch phone .i wanna to change internal numberoldboy wrote:have you got 4760 ?
so open up attendant and then go to keyboard and the extn you are trying to delete will be supervised there delete that supervision and then you can delete user.
open in administrator mode. but I can not delete. I'm doing something wrong. Only 16104 16147 I want to change that number.You can see the picture belowoldboy wrote:so open up attendant and then go to keyboard and the extn you are trying to delete will be supervised there delete that supervision and then you can delete user.
http://j1311.hizliresim.com/1h/x/uzpc3.jpg
http://k1311.hizliresim.com/1h/x/uzpp5.jpg
make key 7 on attendant not assigned then validate, then delete 16104
