8128 stuck in "connecting" screen
sayuri88
Post by sayuri88 »
i have successfully connected to the SSID,
and got the required IP Address and TFTP address
but the 8128 still stuck at connecting screen
able to do a ping to the 8128 Phone ip address
OXE Release : R11.0-k1.400-25-f-sg-c7s2
DHCP on OXE
created class : alcatel.mipt.1
alcatel.mipt.0 has been created by default
did lanpbxmipt -auto also
Controller used : Aruba
AP used : AP 93
please advice
Re: 8128 stuck in "connecting" screen
Is it one phone only, or all phones ?
sayuri88
Post by sayuri88 »
All the phones
Konstantinos.E
Post by Konstantinos.E »
Just an idea
try to give static ip configuration and if the phone gets in service then give DHCP.The phone must download cfg file from the pbx. I had this problem in the past and i solve it this way. There is a tftp option in controller that must be provided to the DHCP request to allow tftp download to get this file .i suppose thats why show connecting..
Alca_holic
All the phones..? Did you setup your lanpbx.cfg file ?
sayuri88
Post by sayuri88 »
Solved,
There's no return path in the router between the 2 network
Return to “Mobile IPTouch Phones (MIPT)”
