MIPT 81X8 -> DHCP <-> static IP Configuration
Chris-tian-Baden
Post by Chris-tian-Baden » 10 Jul 2014 08:59
I`ve got an question. If an MIPT recieves the IP per DHCP Server and the dhcp doens`t deliver an tftp Server address.
Will then the static config tftp in the 81X8 work or not?
Which adjustment ist higher in hierarchical addressing? DHCP or Static?
kind regards
ACFE ICS, ACFE AOS, ACFE OAW
Re: MIPT 81X8 -> DHCP <-> static IP Configuration
Post by silvio » 11 Jul 2014 12:07
In my knowledge the static confic (via winpdm) is prefered.
Chris-tian-Baden
Post by Chris-tian-Baden » 13 Aug 2014 05:56
Thx, we found another solution to differentiate between 4 nodes, we chancged the "vendor class" in two mipt (to test) an the dhcp-server differntiates based of the "vendor classes".
We called them simply for e.g. "node1.class", "node2.class".....so it`s flexible and everything is done by dhcp server:-)
chris
krishjan
Post by krishjan » 19 Oct 2016 08:16
Hi Chris
I am trying to register my mipt 8118 via dhcp. Option 66 is used by a different manufacturer device. How do i set vendor class on mipt and on dhcp server so I can override option 66?
Thanks,
krishjan
ameliared
Post by ameliared » 04 Feb 2019 08:12
DA low
Return to “Mobile IPTouch Phones (MIPT)”
