8118 stuck on interphony
jonnyred
Post by jonnyred »
I appear to have a user who reports that their 8118 handset is stuck on auto answer, and i cant find anything reference this in the manuals i have. Anyone have any ideas how to switch it back off ? Cheers.
Re: 8118 stuck on interphony
I know this "feature" together with dect mobiles. If headset function is enabled than the phone is on auto answer. Maybe this is the same at the wlan phone.
jonnyred
Post by jonnyred »
Thanks we will have a look into that and i will report back any findings.
jonnyred
Post by jonnyred »
I would like to add that this auto answer appears to only affect only internal calls, not onlt external ddi calls ?
Delete the set on OXE and recreate
Return to “Mobile IPTouch Phones (MIPT)”
