Multiple analog sets keep ringing by themselves at night without a wakeup
Hi guys ,
i have a customer (hotel) with a system 4400 R 2.1 . Multiple analog sets ,usually the same rooms, start ringing by themselves at night hours 2am 3am 5am etc and i can't find a solution. i have tried everything . I have changed the cpu , dton , signal units , i even moved some analog cards to a different shelf, disabled messaging , did some changes with grounding but the problem does not go away. I can't think of anything else. please someone help.
- Konstantinos.E
- Konstantinos.E
ela re patrioth!!!:) i am from Greece yes.
about your problem.can you explain a bit better what exacly the problem is and what changes you made to fix the problem.
Did you tryed to change the cards?do you have PRA cards?
Did you try to restore the system?maybe the database crashed in some way.
Do you have DID in every room?
Do you have any incident?
