problem with missed call LED button on 4038/4068
milinn
Post by milinn »
I have problem with upgraded OXE from R8 to R11.230032a. After a month from upgrade we found problem, that notifiaction button of missed calls stop blinking. On 4018 it works normal but on the better phone like 4038/4068 it stoped.
So I decided to update OXE to last one version R11.230033a but the problem still persist. In incvisu I found that errors:
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1345)
18/04/17 08:09:34 000001M|---/--/-/---|=3:1613=15.04.0c.00.01.01.80.13.08.ff.00.00.00.00.00
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1373)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1349)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1346)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1366)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1362)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1375)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1068)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1089)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1369)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1090)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1094)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1080)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1325)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1116)
18/04/17 08:09:34 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1133)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1141)
18/04/17 08:09:35 000001M|---/--/-/---|=3:1613=15.04.0c.00.01.01.80.13.08.ff.00.00.00.00.00
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1067)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1162)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1188)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1212)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1254)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1285)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1153)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1372)
18/04/17 08:09:35 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 12 (neqt 1327)
From incifno I read that there were some problem with delete operations. But how to solve that not :(
So I try to change in user settings type of phone from IP touch 4038 to IP touch 8038 and waiting till phone take wrong binaries and after that I change it back to take correct one, but problem still persist. I dont know what could to do to solve that problem with missed call notification LED. Have anyone know what problem there be ? Or any possible solutions how to solve that ? I will be very grateful for any advice. Thank you !
Re: problem with missed call LED button on 4038/4068
Problem - with all sets or with some of them? If you create new user - problem the same?
ippstat - menu about IP set download - all IP set have right binary?
milinn
Post by milinn »
Problem is with all sets 4038/4068
when we create new one user, problem persist, nothing changed
***Current version for V1  Ip Phone (10  Mega) is 00.05.2
***Current version for V1s Ip Phone (100 Mega) is 00.03.0
***Current version for Ipp_Int Ip Phone Integre (100 Mega) is 2.31.00
***Current version for IP Touch is :
        - A(4018),Z(4008)               bootloader      4.33.81
                                        application     4.33.81
                                        data            4.33.81
        - B(4028),C(4038),D(4068)       bootloader      4.33.40
                                        application     4.33.40
                                        data            4.33.40
        - AG(4018),ZG(4008)             bootloader      NotFound
                                        application     NotFound
                                        data            NotFound
        - BG(4028),CG(4038),DG(4068)    bootloader      4.34.21
                                        application     4.34.21
                                        data            4.34.21
        - 8082                          application     4.51.00
        - 8018
                                        bootloader      4.90.70
                                        application     4.90.70
        - NOE3G(8028,8038,8068)
                                        bootloader      4.52.60
                                        application     4.52.60
                                        data            4.52.60
        - AEE(4018EE),ZEE(4008EE)
                                        SIP             2.12.40
        - BEE(4028EE),CEE(4038EE),DEE(4068EE)
                                        SIP             2.12.40
        - soft version for 'Mobile IP Touch 300/600 ' is 109.025
        - soft version for 'Mobile IP Touch 310/610 ' is 120.028
        - soft version for 'Mobile IP Touch 8118/8128 ' is 5.5.4
*** Use 'tftp_check -L' to see and force system to take new
   Localization or customization files ***
** 296 Ip phones are declared on this node !!
** 36 Ip phones are not updated with the right binary !!
** 0 Ip phones can be reset for download !!
You have "36 Ip phones are not updated with the right binary " - all of them 4038/4068?
tgn
Post by tgn »
if you have an opentouch or ics connected -> switch "display unanswered calls if homepage app" to true in 8/9 phone cos.
regards...
milinn
Post by milinn »
thank you tgn, now it works for me :)
milinn
Post by milinn »
but the errors from the first post doesnt disappeard :/ so something must be still wrong
From your ippstat output - "36 Ip phones are not updated with the right binary " - try to find IP set not updated (check download policy in Phone feature COS, try with ASAP, restart phones)
tgn
Post by tgn »
the incidents are related to an issue if a PRS is present (on opentouch or ics). you can ignore them. i've a hotfix from R&D for this (but haven't it installed yet)
regards...
Return to “MAIN”
