Hi all,
we need to find some device that permit us to install 40 analog phone from the Oxe R12 that are in 6 site connected via fibre optic.
We need some like a master near the pbx and 6 remote device for remote site.
Do you have ever use something like this?
Andrea
Install analog set using media converter on fibre optic connection
Re: Install analog set using media converter on fibre optic connection
You really want to use ONLY fibre optic and analogue phones? If you have IP connection between sites - you can use any FXO/FXS VoIP gateways.
Or use IP phones.
Or use IP phones.
Use SIP gateways, IP Touch or even a media gateway at remote sites. It is easier than converting analog to fiber, then fiber to analog again.
You have a powerful system OXE R12, it is ready for for this kind of solution.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Hi all,
thanks, I know that an Oxe R12 with 1 CS and 9 remote GD is the better way to solve this problem but the customer want fiber -> analog connection.
Regards.
Regards.
Not clear, customer want:
- central node with many SLI boards - FXO_to_FO_convertor - FO - FO_to_FXS_convertor - analogue phones, or
- central node with IP licences - media_convertor - FO - media_convertor - VoIP_gateway (like AudioCodes) - analogue phones
Exist just FO for telephones? Or exist LAN/WAN connection (and can be used IP phones).
What reason (from customer point of view) for analogue phones using? The best remote device (but with IP connection) - remote shelf with GD.
I know this is a customer of energy central system and need all the phone in IP66 protection category so no digital phone and no ip phone from ALE.
I propose 1 CS with 8 remote GD and 1 SLI card in all remote GD.
The request is like this because the customer have a proprietary fiber optic ring in all sites and, I don't know why, don't want SIP phone of third party.
It's a strange customer.
