AHL
leobtm
AHL
Post by leobtm »
Hi everybody, I am taking over the maintenance of Alcatel 4300M PABX. Currently IT team wants to integrate PMS with pabx. They ask if AHL is already installed in the pabx.
my question is:
1. Does the 4300M support with AHL?
2. If yes, how to find out whether it is installed or not, while purchase documentation no longer.
Thanks in advance and really appreciate the answer.
Sorry for my bad english
Re: AHL
Holly still using a 4300 for new integrations? Good luck with that
leobtm
Re: AHL
Post by leobtm »
cavagnaro wrote:Holly still using a 4300 for new integrations? Good luck with that
Thanks for your respond cavagnaro. So you mean 4300M can not be integrated with PMS. Honestly i am new in Alcatel system and i need enlightenment.
Sent from my Mi Note 2 using Tapatalk
Re: AHL
No clue, what I mean is that 4300 is an already faced out hardware, solid but without any support or development.
I found some manuals here:
https://www.systemstl.co.uk/item/13386- ... 00-manuals
leobtm
Re: AHL
Post by leobtm »
cavagnaro wrote:No clue, what I mean is that 4300 is an already faced out hardware, solid but without any support or development.
Thanks for the hint and will check the manuals.
Return to “MAIN”
