PC Installer
Locked
Nico_1
PC Installer
Post by Nico_1 » 13 Oct 2015 02:33
Hi guys,
i have a problem with the PC Installer Software, i open the PC Installer an then its came this error massage: " 'C.' no valid call handling delivery found on this drive please insert a CD-ROM in the matching drive". What can i do to fix the problem?
I use the version 4.0 on Windows 7 Professional 64bit
Thanks for help :)
Re: PC Installer
Post by tot3nkopf » 13 Oct 2015 08:28
Put your delivery on c drive as suggested or change drive path in PC installer settings.
Nico_1
Re: PC Installer
Post by Nico_1 » 14 Oct 2015 07:15
Thanks i have forgotten that little detail :/
Locked
Return to “Software Loading”
