How can I load R12 Release on CS ? without use From Scratch method
jpissot
Post by jpissot » 11 Sep 2017 09:32
I have to load 5 PCS card from R10 to R12 M1.403.12.g.
I try to use Inactive Partition Metho, but i have messages :
error: failed dependencies:
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by coreutils-8.4-19.el6_2alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by e2fsprogs-1.41.12-21.el6_1alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by glib2-2.22.5-7.el6_8alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by glibc-2.12-1.149.el6.5_1alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by gzip-1.4-1_4alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by ncurses-base-5.7-3.20090208.el6_2alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by perl-5.10.1-136.el6_1alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by procps-3.2.8-25.el6_2alcy
rpmlib(PartialHardlinkSets) <= 4.0.4-1 is needed by tzdata-2016a-2.el6_2alcy
On BPWS, i find that the "Inactive Version Method" to R12 is not compatible.
I ve tried to use the choice 9 of menu switch "Remote Dowload". The choice 4 works fine, but the choice 1 indicates also the same errors:
How can I do because the PCS cards are on remote sites, I dont want to go there.
Thanks for your help
tgn
Post by tgn » 12 Sep 2017 01:53
jpissot wrote: On BPWS, i find that the "Inactive Version Method" to R12 is not compatible.
as you see by yourself.... ALE has a reason to write it is incompatible...
install a new pcs on your site, send it to the remote site and instruct somebody to change the board.
regards...
oldboy
Re: How can I load R12 Release on CS ? without use From Scratch method
Post by oldboy » 12 Sep 2017 02:27
Not possible!!! must be a fresh load
mgoegel
Post by mgoegel » 12 Sep 2017 14:39
I'm going to prepare raspberry pi's for this job.
Have many pcs outside (world-wide) to upgrade and no people who could hold a screwdriver. Maybe I can bring them to plug in usb power supply and 2 patch cables...
Regards, Mario
Gesendet von iPad mit Tapatalk
Vinnie
Post by Vinnie » 12 Sep 2017 16:39
jpissot wrote:Hi,
Remove from the Main CPU anda configure again. I have the same solution and have to made those steps.
Enviado do meu iPhone usando o Tapatalk
Vinnie
Post by Vinnie » 12 Sep 2017 17:42
Sorry i didn't answered correctly. It's really necessary to upgrade from the scratch. I have 6 pcs and i need to go to the sites.
Vinnie
Post by Vinnie » 12 Sep 2017 17:43
According to Alcatel procedure.
adriano_santos
Post by adriano_santos » 29 Mar 2018 18:09
Dear,
Unfortunately since release 12, it is no longer possible to install from the inactive partition, one should make a copy of the database, save. and subsequently perform a zero installation using the new release, the installed database can restore the database.
I hope I have helped, regards.
Adriano Santos
mgoegel
Post by mgoegel » 30 Mar 2018 04:50
Hello Adriano,
this statement isn't 100% correct.
It isn't possible to do this from <R12 to R12 and above.
From R12 to R12.1 (or higher, for now) you can use this method again.
Regards Mario
Return to “Software Loading”
