Hi all,
I'm trying to load the R6.1.1 binary file on GD2 card but unable to do.presently Gd is having R8.0 but i'm able to change it to R7.1 and not to R6.1.1 the error i got is damaged or corrupted file.
Even i had downloaded the R6.1.1 from BPWS site but still it is not working.
can anyone gives the tips.
Rgds
Gd2 Binary Flashing
- knightr1der
Re: Gd2 Binary Flashing
What specific version of 6.1.1 are you trying?
TECHNICAL COMMUNICATION No. TC0904 Ed. 04 should help you
History repeats itself - because no one listens the first time!
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
- OmniTouch CC Premium R8.x
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
- knightr1der
according to the TC, the version you have for 6.1.1 is a good one.
Are you seeing 30.31 as the version number in your PC installer window when you trying to load software to the GD2?
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
Dagar wrote:Its R6.1.1-f2.502.33a
Thanks Its working.
My Gd2 was faulty,On GA2 i have flashed the R6.1.1-f2.502.33a and made it GD2.
Thanks.
