I tried to setup a SIP-Trunk between Elastix and Alcatel OmniPCX Office (I am new to all this). Calling from Elastix to Alcatel internal subscribers
and from Alcatel to Elastix works, also external incoming calls get routed to the Elastix appliance (via DDI). Talking to each
other also works good. But now I am stuck... got the problem, that when I dial an external number from my SIP-Phone connected to Elastix I can't get out. The error in SIP trace log is like "Got SIP response 502 "Bad Gateway" back from 'Alcatel IP Address'" and "Dial failed for some reason with DIALSTATUS = CONGESTION"HANGUPCAUSE = 27"). My Alcatel OXO Configuration is like the one posted by tot3nkopf, SIP-Extension is 111.
Asterisk Outgoing Trunk Configuration:
host='Alcatel IP Address'
type=peer
qualify=yes
transfer=yes
dtmf=rfc3325
immediate=no
insecure=very
[May 15 14:00:50] VERBOSE[3845] netsock.c: == Using SIP RTP TOS bits 184
[May 15 14:00:50] VERBOSE[3845] netsock.c: == Using SIP RTP CoS mark 5
[May 15 14:00:50] VERBOSE[3845] app_dial.c: -- Called OXO/00152xxxxx876
[May 15 14:00:50] VERBOSE[3171] chan_sip.c: -- Got SIP response 502 "Bad Gateway" back from 'Alcatel IP Address'
[May 15 14:00:50] VERBOSE[3845] app_dial.c: -- SIP/OXO-00000023 is circuit-busy
[May 15 14:00:50] VERBOSE[3845] app_dial.c: == Everyone is busy/congested at this time (1:0/1/0)
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-dialout-trunk:20] NoOp("SIP/111-00000022", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 27") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-dialout-trunk:21] Goto("SIP/111-00000022", "s-CONGESTION,1") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Goto (macro-dialout-trunk,s-CONGESTION,1)
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/111-00000022", "RC=27") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/111-00000022", "27,1") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Goto (macro-dialout-trunk,27,1)
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [27@macro-dialout-trunk:1] Goto("SIP/111-00000022", "continue,1") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Goto (macro-dialout-trunk,continue,1)
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [continue@macro-dialout-trunk:1] GotoIf("SIP/111-00000022", "0?noreport") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [continue@macro-dialout-trunk:2] AGI("SIP/111-00000022", "trunklog") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [continue@macro-dialout-trunk:3] NoOp("SIP/111-00000022", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 27 - failing through to other trunks") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [continue@macro-dialout-trunk:4] Set("SIP/111-00000022", "CALLERID(number)=111") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [0015206475846@from-internal:5] Macro("SIP/111-00000022", "outisbusy,") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-outisbusy:1] Progress("SIP/111-00000022", "") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-outisbusy:2] GotoIf("SIP/111-00000022", "0?emergency,1") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-outisbusy:3] GotoIf("SIP/111-00000022", "0?intracompany,1") in new stack
[May 15 14:00:50] VERBOSE[3845] pbx.c: -- Executing [s@macro-outisbusy:4] Playback("SIP/111-00000022", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
[May 15 14:00:50] VERBOSE[3845] file.c: -- <SIP/111-00000022> Playing 'all-circuits-busy-now.gsm' (language 'en')
[May 15 14:00:52] VERBOSE[3845] file.c: -- <SIP/111-00000022> Playing 'pls-try-call-later.gsm' (language 'en')
[May 15 14:00:53] VERBOSE[3171] chan_sip.c: -- Registered SIP '111' at 10.44.172.109 port 53303
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [s@macro-outisbusy:5] Congestion("SIP/111-00000022", "20") in new stack
[May 15 14:00:54] WARNING[3845] channel.c: Prodding channel 'SIP/111-00000022' failed
[May 15 14:00:54] VERBOSE[3845] app_macro.c: == Spawn extension (macro-outisbusy, s, 5) exited non-zero on 'SIP/111-00000022' in macro 'outisbusy'
[May 15 14:00:54] VERBOSE[3845] pbx.c: == Spawn extension (from-internal, 0015206475846, 5) exited non-zero on 'SIP/111-00000022'
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [h@from-internal:1] Macro("SIP/111-00000022", "hangupcall") in new stack
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/111-00000022", "1?skiprg") in new stack
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Goto (macro-hangupcall,s,4)
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [s@macro-hangupcall:4] GotoIf("SIP/111-00000022", "1?skipblkvm") in new stack
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Goto (macro-hangupcall,s,7)
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [s@macro-hangupcall:7] GotoIf("SIP/111-00000022", "1?theend") in new stack
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Goto (macro-hangupcall,s,9)
[May 15 14:00:54] VERBOSE[3845] pbx.c: -- Executing [s@macro-hangupcall:9] Hangup("SIP/111-00000022", "") in new stack
[May 15 14:00:54] VERBOSE[3845] app_macro.c: == Spawn extension (macro-hangupcall, s, 9) exited non-zero on 'SIP/111-00000022' in macro 'hangupcall'
[May 15 14:00:54] VERBOSE[3845] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/111-00000022'
