Asterisk and OXE r10.0.49 calling error
hi, i'm connecting last asterisk version with oxe r10.0.49, i have managed to connect the gateways, OXE says "in service" and asterisk OK so i made an outbound route from asterisk to oxe, and i try to call but an autoattendant come up and says that device is busy.
any help?
Edit: Asterisk CLI says this when i try to call: [2448][C-00000016]channel.c:4816 ast_prod: Prodding channel 'SIP/6001-00000022' failed
any help?
- cavagnaro
Re: Asterisk and OXE r10.0.49 calling error
Search on the forum on how to activate SIP traces on OXE and post a full detailed log. Magic balls are out of service for the moment
most failure in my test enviroments was this ->
for incoming calls in oxe a gd with free compessor hardware must be in service...
regards...
regards...
i add the sip trace to this post, info for analisys
i have two gateways, one with Asterisk1(192.168.1.98) a another with Asterisk2(192.168.1.88) in my lab, this time Asterisk2 is shutdown so ignore IP 192.168.1.88 errors, OXE have IP 192.168.1.97
tgn:
thanks, there is the posibility to virtualizate GD or i have to go to real hardware?
tgn:
- cavagnaro
Real hardware only so please confirm us that this is your scenario. Otherwise no need for further analysis
I have the three virtual machines running on a 2008 server, the only solution is to use GD?
I only use IPTouch 4038 for OXE, for asterisk all softphones.
Another question i have 0 standard sip licences and 350 andavanced sip licences what is the difference?
I have the virtual machines running on server, i only use ip phones, so GD is really needed?
I use iptouch for oxe and sip softphones for asterisk, there is a ip phone for oxe?
Last question what is the difference between standard and advanced sip users in OXE
i think gd and inip3 can play cpu role but cpu can't play gd or intip role
so real hardewares are mandatory .
btw no call setup is seen in your siptrace only options
as said before .... real hardware (gd/gd3/intip/intip3) is mandatory.
regards...
regards...
- cavagnaro
How are you implementing this if you have no idea on what you are doing? Please ask some professional services for you.
