hi,
I have bought on ebay an Ip phone e-reflexe (4035).
I don't know how to connect it with my trixbox server.
the trouble is due to the tftp server (on trixbox) i don't know how it works...
trouble in connecting IPPHONE trixbox
- cavagnaro
Re: trouble in connecting IPPHONE trixbox
4035 uses a propieraty protocol. You can't connect it to anything that is not an Alcatel PBX. Hope you bought it for your Alcatel and want to try to connect it to Asterisk...
thx for u r anwser. Someone had told me that he had made work this phone with Asterisk. I hoped that he wasn't pulling my leg....
- cavagnaro
I really doubt it. those phones are IP and uses a protocol UA, if Asterisk can make them work they are in serious problems because that is not an open protocol and they are using it without permission...so I guess it is not likely.
