Ththththaats all folks. Too dangerous to continue
Dear Santa, I'd like a OXE virtualization on my PC. Can you help ?
cheo
Post by cheo »
Hi guys,
I'm installing an OXE-V on ESXi 5.5 with following steps by steps the procedure but I've an issue.
I start OmniPCX Enterprise PC Installer with Linux + Call Handling:
- Blade Server
- My version l130124g I also try with l130126a
- My country
etc ...
I succeed to install Linux part but when it's Call Handling part I've the error :
DHS3bin/oneshot/mtcl/business.cron
DHS3bin/oneshot/mtcl/hotel.cron
DHS3bin/oneshot/mtcl/mastercopy
DHS3bin/oneshot/mtcl/rsh_mao
DHS3bin/oneshot/mtcl/rsh_blf
DHS3bin/oneshot/mtcl/rsh_tarfil
DHS3bin/oneshot/mtcl/test_ops
DHS3bin/oneshot/mtcl/lockmem
DHS3bin/oneshot/mtcl/inc_info
DHS3bin/oneshot/mtcl/dbdump
DHS3bin/oneshot/mtcl/survroot
DHS3bin/oneshot/mtcl/syscompat
DHS3bin/oneshot/mtcl/savesyms
DHS3bin/oneshot/mtcl/twincompat
DHS3bin/oneshot/mtcl/allcompat
DHS3bin/oneshot/mtcl/dbrecover
DHS3bin/oneshot/mtcl/aff_incid
DHS3bin/oneshot/mtcl/clockstat
DHS3bin/oneshot/mtcl/daylight
DHS3bin/oneshot/mtcl/ps_logger
DHS3bin/oneshot/mtcl/setpgrp
DHS3bin/oneshot/mtcl/octelj.blf
DHS3bin/oneshot/mtcl/vg.blf
Kernel panic: Ththththaats all folks. Too dangerous to continue
Parameters of my VM:
- 1 vCPU
- 1 GB RAM
- Hard Drive 40 Gb
- Hyperthreaded Core Sharing to None
Somebody can help ?
ltatge
Re: Ththththaats all folks. Too dangerous to continue
Post by ltatge »
Hi cheo,
If you know Alcatel-Lucent products you know where to find docs. In Business Portal are several docs for virtual installation.
I have had this error once, but don't remember the solution. I followed docs and succeeded. Try using ALEDS tool to delpoy OXE-V.
Regards LT
cheo
Post by cheo »
Yes I went on the BP already. These error seems to be due to the size of the hard drive but my VM has already 40GB, no more, no less.
But now it's good, I modify the SCSI controller and now seems to be good.
ltatge
Post by ltatge »
Shure, I don't know why the specs of virtual hardware settings of OXE are at the end of the document.
To make sure you read it all lol
Enviado de meu C6602 usando Tapatalk
tgn
Post by tgn »
[serious mode off]
:D :D :D
this command should turn your pdf "backside down"...
pdftk file.pdf cat end-1 output file_reverse.pdf
so the "important" information will be on the first side...
:D :D :D
[serious mode on]
regards...
Problem was driver used by VMware. By default VMware uses scsi but oxe doesn't like that.
Return to “VMWARE”
