run a script in oxe unix/linux as a service
does any one knows how to run a script in oxe as a service to start once the oxe start up?
Re: run a script in oxe unix/linux as a service
Usually you would have a script in /etc/init.d/ and then link it to the different run-levels rc1.d/ to rc7.d/ according "where" it is supposed to start.
I am not sure that this is supported on the OXO or if there are any automatic cleaning scripts .... (I believe you could not write there because you have no root rights as far as I know...)
-benny
-benny
Benny
Benny
- tot3nkopf
But we do have OXE's root password Benny, and we can run scripts.benny wrote:Usually you would have a script in /etc/init.d/ and then link it to the different run-levels rc1.d/ to rc7.d/ according "where" it is supposed to start.
-benny
Regards.
