Reset board everyday at 5 am
Did you say hacking ?
ortega
Post by ortega »
Hi!
I want to make an automatic reset to a board everyday at 5 am.
I made the script resetbra
#! /bin/sh
tool rstcpl 0 15
This is working. Now I want to call this script everyday at 5 am so I need to put it in the crontab.
But I don't know how to put it in the crontab (which file?) because it's a Release 3.2.
Any help?
Thanks in advance.
krzysioD
Re: Reset board everyday at 5 am
Post by krzysioD »
crontab -l
crontab -e
for start,
iirc it was a cronCfg ? Sorry, memoria fragilis...
alex
Post by alex »
It is UNIX question, not 4400 question.
man cron
ortega
Post by ortega »
man cron
man: not found
I'm in a release 3.2.
It's not only Unix. There's issues. I couldn't call the command rstcpl directly (it's not a Unix command).
It's working. Here's how I did it, for future reference:
in /usr2/mtcl i created the text file resetbra:
#!/bin/sh
date
/usr2/oneshot/mtcl/tool rstcpl 0 15
then I gave it permission to execute
chmod 777 resetbra
Then I entered in superusermode
Gave the command crontab and entered the line
0 7 * * * /usr2/mtcl/resetbra >> /usr2/mtcl/logreset.txt
ctrl+d to exit the edition of crontab
crontab -l shows the crontab file.
And everyday at 7 Am a reset is being made to the Bra card in the slot 0-15. The date and time of the reset is put in the log file logreset.txt.
Thanks for your answers and your help.
Gedeon
Post by Gedeon »
Don't use root account for tool commands.
You can have problems after to acces files (ie database, account files, etc...).
Use only mtcl (or mtch) account for this.
G.
ortega
Post by ortega »
OK. Thanks for the advice.
hojzle
Post by hojzle »
I would also like to reset PRA board automaticaly every day at 5am.
Can you please tell how to do it for release 8.0.1.
Best regards
Should be the same, have you tried at least?
hojzle
Post by hojzle »
No I didn't.
I'll try it and let you know the result.
Best regards
mmt1359
Post by mmt1359 »
very good
Return to “System Hacking”
