Trunk supervision keys on the set
Go ahead, shoot for the feature requests, and if anyone knows the solution, they will share it with you. If there is a lot of people who request something, I will make a marketing request directly with Alcatel. A good idea would be to create a poll with each request. Alcatel-Lucent is aware of this forum.
Re: Trunk supervision keys on the set
murraya wrote:just a thought as never tried it, set the pmla extn as off hook routing immed to the trunk gp prefix. maybe when you press the smla key instead of getting dialtone from pmla it might route you to the trunk.
How would you do that Murray? MLA is not an extension.
swinstation
Post by swinstation »
actually I defined PMLA as delay routing and modified set routing no when she presses the PML after 3 sec if dial another extension the extension rings but if she dose not take action seize the trunk.but I did not try on SMLA I will try it .
Maybe with virtual extensions. Is that what you are saying Murray?
murraya
Post by murraya »
correct, I mean set up a ua virtual with the PMLA (of the virtual's number) and off hook the virtual.
as I said just a thought.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
murraya
Post by murraya »
just tried it :) :) :)
failed completly :( :( :(
murraya is now :oops: :oops:
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
swinstation
hi
Dear friends
as I said I tried with delay off-hook (hotline) on PMLA and it works but I will try it on SMLA tomorrow.
anyway I appriciated your helps.
swinstation
I tried on SMLA,but it dosen't work.so I really appreciated about your helps.
specially murraya and tot3nkopf
Locked
Return to “Feature Request”
