phone speaker led
Go ahead, shoot for the feature requests, and if anyone knows the solution, they will share it with you. If there is a lot of people who request something, I will make a marketing request directly with Alcatel. A good idea would be to create a poll with each request. Alcatel-Lucent is aware of this forum.
fery_s
phone speaker led
Post by fery_s » 09 Nov 2014 00:49
on of my customer has series8/9 phones and crystal oxe with R9.he wants when the phone ringing the speaker led (hand set led) blinking.
In addition,it blinking already but for reason that i don't know it does'nt blinking anymore.
if anyone known about this feature please help me.
Re: phone speaker led
Post by cavagnaro » 09 Nov 2014 09:51
Check the set type configuration on OXE. Also if auto answer is enabled or not
fery_s
Post by fery_s » 09 Nov 2014 11:13
The phones type are 4018 & 4039 and auto answer is disable.
Post by cavagnaro » 10 Nov 2014 05:24
Yes, but in OXE, are they configured like those? Sometimes a bad configuration sets a 4068 as a 4038 for example and even when phone works it behaves and looks bad
fery_s
Post by fery_s » 10 Nov 2014 07:41
i know that.configure is correct and set type match to phone.all features is work correctly just the speaker(handset) led is off when the phone ringing.
Post by vad » 10 Nov 2014 22:54
I think this is not possible.
Speaker led:
- OFF - phone loudspeaker switched off
- ON - hands-free On
- Flash - phone loudspeaker and handset loudspeaker work at the same time.
Ask your customer - may be enough to customise ring melody (in this case user understand - which telephone ring)?
fery_s
Post by fery_s » 13 Nov 2014 00:36
It is posible. At know when the attendant call users the led blinking but not working for when user call user
Post by cavagnaro » 13 Nov 2014 06:12
I have tested this on two customers and never happens. Asked users if they ever saw that button blink and answer was never. So, I agree again with vad. If you say it is possible and we after tested and vad by huge experience say is not, then, something must be missing from your side. Maybe was another configuration. Maybe they used headsets. But not by default.
Post by vad » 13 Nov 2014 06:43
May be for attendant - we have some specific behaviour. F.e. when attendant dial user number (but not calls) - user "reserved" for attendant and so on.
But about usual calls - I never hear about specific management for speaker LED.
Return to “Feature Request”
