Alcatel Office 4200e Technical Files CD
Use this forum if you want to hire someone, or if you are looking for a job :-)
Mezzaluna
Post by Mezzaluna » 30 Dec 2016 06:51
Hi Guys i found this CD from r4.0 which i used to use back in the day. It would be handy to be able to use it. Any suggestionns??
It will not run on win 7 64bit and when i run it on a virtual XP machine it will not install either. Any suggestions or method to get these files to load?? I can upload the cd on to an ISO if required.
Thanks Joe
KoenC
Re: Alcatel Office 4200e Technical Files CD
Post by KoenC » 05 Jan 2017 06:06
Hi Mezzaluna,
Try loading it with a 32-bit computer. I ran into the same problem with my Win10 64-bit and all worked well on my old laptop (Win 7 - 32bit).
Good luck
Grts
If I'm ever on life support, unplug me. Then plug me back in, see if that works...
mdiver
Post by mdiver » 18 Jan 2017 14:56
Use winrar to extract the installer package and remove the files you want
Return to “JOBS”
