HMS TECHNOLOGIES, INC - PBX Technician - Salem, VA
Use this forum if you want to hire someone, or if you are looking for a job :-)
glenwoodmorganjr
Post by glenwoodmorganjr »
Providing all on-site voice system PBX Operation and Maintenance (O&M) for all Customer's companies and associated facilities in accordance with the OEM specifications of equipment. This includes O&M on hardware, software, ports, common equipment, station, trunk and cards. Moves, adds, changes and disconnects will be a part of the primary responsibilities as well as providing and updating infrastructure documentation and reports, providing security support, inventory control, change management, preventive maintenance and training as required by the Customer.
The primary responsibilities of the PBX Technician include but are not limited to the following:
• Install, setup and diagnose and solve problems on PBX phone systems, network and data equipment.
• Route and install cables and test lines to ensure appropriate signal quality.
• Perform installation, maintenance and troubleshooting on Key PBX systems.
• Testing, troubleshooting, cutting over, and turning up of phone lines.
• At customer premises locations identify demark, pretest and install IAD and loop testing.
• Troubleshoot telephone system hardware/software, voicemail, and telephone set and feature issues on site and remotely.
• Analyze VS systems and make recommendations for modernization.
Required Skills and Experience:
• Bachelor's Degree in Electrical Engineering, Computer Science, Information Systems, Information Technology or other related technical discipline AND 8 yrs. of telecommunications experience installing and cutting cable lines. 8 years of additional relevant experience may be considered in lieu of a degree.
• OEM Certification.
• Experience with basic VoIP; VS PBX systems.
• Prior experience setting and testing of telephone sets, installing new cable jacks, IDF crosscutting and documentation.
• Familiarity with resolving PBX problems and Critical PABX failures (e.g. Emergency Replacement System PBX).
• Experienced with VS, Key and PBX phone systems.
• Ability to work individually or in an Agile team setting.
• Exceptional verbal and written English communication skills.
Desired/Preferred Skills and Experience:
• Government Agency contracting experience; VA preferred (VBA/VHA).
• Cisco certifications.
Experience with the following systems: Alcatel-Lucent, Omni Private Communications Exchange (PCX) 4400 solution, Applied Voice and Speech Technologies (AVST) CallXpress server, Trivium call accounting
solution, Genesys/Alcatel-Lucent virtual hold solution, Innovative Electronic Designs (IED)
8000 Series public announcement system, Gordon Kapes 922 system
Who May Apply: US Citizen or Green Card; This employer participates in the e-Verify program.
Security Clearance: MBI - Moderate Background Investigation
Travel Requirements:
• 10% local Travel
Disclaimer
The above statements are intended to describe the general nature and level of work being performed by people assigned to this classification. They are not to be construed as an exhaustive list of all responsibilities, duties, and skills required of personnel so classified. All personnel may be required to perform duties outside of their normal responsibilities from time to time, as needed.
Glenwood Morgan Jr.
Talent Acquisition Specialist
(703) 831-2391 Mobile
glen.morgan@hmstech.com
HMS TECHNOLOGIES, INC.
A Certified Service Disabled Veteran-Owned Small Business (SDVOSB)
One Discovery Place
Martinsburg, WV 25403
304-596-5583
www.hmstech.com
This electronic message contains information from HMS TECHNOLOGIES INC, which may be company sensitive, proprietary, privileged or otherwise protected from disclosure. The information is intended to be used solely by the recipient(s) named above. If you are not an intended recipient, be aware that any review, disclosure, copying, distribution or use of this transmission or its contents is prohibited. With the exception of messages sent by authorized HMS TECHNOLOGIES INC. contracts or purchasing personnel, nothing in this message may be interpreted as a digital or electronic signature that can be used to: (a) authenticate either the submission or the acceptance of a proposal or offer to contract, or (b) modify an existing contract. If you have received this transmission in error, please notify us immediately at postmaster@hmstech.com.
Return to “JOBS”
